Shielding your control cavity with copper tape is one of the highest-value upgrades on a single-coil guitar. It reduces hum and interference that single-coil pickups pick up from fluorescent lights, computer monitors, and other electronics. Here is when it matters and how to do it properly.
Does your guitar need shielding?
Humbuckers reject hum by design. If your guitar has only humbuckers, shielding the cavity adds minimal benefit. If your guitar has any single-coil pickups, shielding makes a real difference.
The symptoms of a shielding problem: you hear hum when you face a particular direction in the room, hum that changes when you move near electronics, or hum that increases when your hands are off the strings.
- Adhesive-backed copper tape (available at electronics suppliers or guitar parts vendors). Get tape that is at least 25mm wide. Very thin tape is harder to work with.
- Burnishing tool or a smooth stylus
- Small scissors
- Continuity tester or multimeter (to verify the shield is grounded)
Step 1: Clean the cavity
Remove all electronics. Wipe the cavity walls and floor with a dry cloth. Any residue or dust affects adhesion.
Step 2: Apply tape to the cavity walls
Cut strips long enough to run from one edge to another. Apply tape to the floor first, then each wall. Overlap each piece onto adjacent pieces by at least 5mm. The overlapping areas need to make electrical contact, not just physical contact.
Step 3: Burnish the overlaps
Press the overlapping tape sections firmly with a smooth tool. Some copper tape has conductive adhesive (overlaps are automatically conductive) and some has non-conductive adhesive (only the copper surface makes contact). Burnish all overlaps regardless: it does not hurt and ensures contact.
Step 4: Apply tape to the cavity cover (if you have one)
Line the inside of the cavity cover with tape as well. When the cover sits on the cavity, the tape on the cover should contact the tape on the cavity rim, completing the Faraday cage.
Step 5: Ground the shield
The shielding only works if it is connected to ground. Run a short wire from one corner of the copper tape to the back of a pot or to your ground bus. Solder a small solder point on the tape (first tin the tape surface with a hot iron and a small amount of solder, then attach the wire). Without this ground connection, you have a floating shield that may actually increase hum.
Step 6: Verify continuity
With a multimeter in continuity mode, touch one probe to the shield copper and the other probe to the pot casing. You should get a continuous connection (beep or low resistance reading). If not, find the break in the tape overlap and re-burnish or add a short jumper wire.
Shielding paint as an alternative
Conductive shielding paint covers irregular cavity shapes that tape is difficult to conform to (carved tops, complex routing). Apply two to three coats, let each dry fully, and ground it the same way as tape.
The improvement is noticeable immediately in a live playing situation. It will not eliminate hum entirely on single-coils (that is physics, not a problem to solve), but it significantly reduces the environmental interference that makes single-coils frustrating in certain rooms.
