HS (Humbucker + Single Coil) — 1 Volume, 1 Tone, 3-Way Import Switch
GKW kits that use this wiring
- HS kits using an import-style (open frame) 3-way switch instead of a toggle switch
Tips
- Import switches have a different terminal layout than standard toggles. If your kit came with an open-frame switch (not an enclosed toggle), use this diagram instead of the toggle version.
- Wire colors may vary between kit batches — match by position, not color.
- Need soldering help? See our Electric Guitar Wiring guide for basics.
Building a Guitar Kit World kit with this wiring? Our HS Wiring Diagram page lists exactly which GKW kits use it, and if you own one of our kits and no diagram matches your electronics, we will draw you one.
