You finished the wiring, plugged in, and got nothing. This is one of the most common moments in a first build, and it is almost always a small, findable fault rather than a ruined guitar. This guide takes you from the symptom to the cause to the exact fix, usually landing at the output jack or a single dull solder joint.
Applies to: any Guitar Kit World electric kit you have wired by hand, whether solid-body, semi-hollow, or hollow-body with a soldered harness. Pre-wired acoustic-electric and bass kits with plug-in connectors have their own short section near the end.
It helps to picture the signal path before you open anything. The signal runs from the pickups, to the selector switch, to the volume and tone controls, to the output jack, and out to your amp, with a shared ground tying it all together. A break anywhere on that chain, or a lost ground, can silence the guitar. For the full circuit, keep the Wiring and Soldering Fundamentals module open alongside your kit’s own diagram.
Find the cause
Match what you hear, or do not hear, to the closest row, then jump to that fix.
| Symptom | Likely cause | Go to |
| Totally dead, no sound in any position | Hot and ground touching at the jack (a short), or a broken joint in the signal path | Fix 1 |
| One pickup is dead, the others work | That pickup’s hot or ground lead is loose, or it is on the wrong selector lug | Fix 2 |
| Crackle, scratch, or spitting | A cold solder joint (dull and gray, not shiny) or a loose lug | Fix 3 |
| Works, then cuts out | A cold or cracked joint, or a loose jack that spins and stresses its wires | Fix 3 |
| A volume or tone knob does nothing | The pot is miswired or a lug is unsoldered. For tone, the capacitor is miswired or not grounded | Fix 4 |
If the guitar plays but hums loudly, that is a grounding problem, not a dead circuit. Go straight to the bridge-ground guidance in the wiring module. And change only one thing at a time, then retest, so you always know what fixed it.
Work through it in this order
Do not start unsoldering. Isolate the fault first, from the easy end inward, so you only reheat the joint that is actually bad.
- The output jack. This is the number one cause of total silence. The hot (signal) wire goes to the shorter tip tab and the ground goes to the longer sleeve tab. If those two touch, or a loose strand bridges them, the guitar goes silent. Check both tabs against your diagram, and make sure the jack nut is tight so the jack cannot spin and twist its own wires.
- The cable and amp. Rule out the obvious before you dig deeper. Try a different guitar cable and a known-good amp or input, and confirm the amp volume is up. A dead cable fakes a dead guitar more often than you would expect.
- The tap test. Plug in, turn the volume up, and tap each pickup’s pole pieces with a metal screwdriver. You should hear each tap through the amp as a knock. This tells you which pickups are alive before you touch a soldering iron.
- The selector. Move the switch through every position, tapping the matching pickup each time. A position that stays silent points at that pickup’s lead or its lug on the selector.
- The pots. Turn each volume and tone control through its full range and listen. The volume should fade the signal up and down. The tone should move from bright to warm. A control that does nothing has a wiring fault at that pot.
- The grounds. Touch a metal string or the bridge. If a hum drops away when you touch it, your bridge ground is doing its job. If the guitar is dead-quiet or several controls misbehave, check that every ground returns to one common point (usually the back of the volume pot) and that the bridge ground makes solid metal-to-metal contact.
This short clip walks through the tap test and sound check that the steps above rely on.
By the time you reach the bottom of the list you will know which part of the circuit is at fault. Now fix that one thing.
Fix 1: Totally dead, no sound in any position
Most often this is the jack or a single broken joint.
- Recheck the jack. With the guitar unplugged, look closely where the two wires meet the jack tabs. Separate any hot and ground that are touching, snip away any stray whisker of wire, and confirm the shorter tip tab carries the hot and the longer sleeve tab carries the ground, matching your diagram.
- Follow the signal path. If the jack is clean, walk the chain the signal takes. The volume pot receives the signal from the selector and passes it on to the tone pot and the output jack, so a single unsoldered or broken lug anywhere along that run kills all sound. Check each joint from the selector to the volume pot to the jack.
- Tap as you go. Use the tap test from the isolation steps above at each pickup and each selector position. Silence at every pickup means the fault is downstream, at the volume pot or the jack. Silence at only some positions sends you to Fix 2.
Fix 2: One pickup is dead, the others work
The rest of the circuit is fine, so the problem is that one pickup or its switch lug.
- Tap that pickup’s pole pieces with a screwdriver. No knock means its signal is not reaching the amp.
- Recheck that pickup’s two leads, the hot and the ground, against your diagram. One of them is usually loose, unsoldered, or landed on the wrong lug of the selector.
- Confirm it sits on the correct selector lug for its position. A hot lead one lug over will play in the wrong switch position, or not at all.
- Reflow any joint that looks dull or barely holds the wire, using the rework steps in Fix 3.
This clip shows how to tap-test the pickups so you can tell which one has gone quiet.
Fix 3: Crackle, scratch, or a sound that cuts out
Intermittent noise and dropouts almost always trace to a cold solder joint or a loose lug. A good joint is shiny, smooth, and slightly concave. A cold joint is dull, gray, and lumpy, it only half-holds the wire, and it will fail sooner or later.
Rework a cold joint like this:
- Unplug the guitar and let the parts cool.
- Wipe the hot iron tip on a damp sponge and tin it with a touch of fresh solder so heat flows well.
- Heat the joint itself, the lug and the wire together, for a second or two. Heat the work, not the solder.
- Feed a little fresh rosin-core solder (the kind that came with your kit, usually a 60/40 tin-lead) into the heated joint until it flows and wets both the lug and the wire.
- Lift the iron away and hold the joint perfectly still until the solder turns from shiny-wet to solid. Moving it while it cools creates another cold joint.
- Check the result. It should be bright and smooth, with the wire clearly wetted in, not sitting in a gray blob.
Also retighten any control or jack nut that has worked loose, because a spinning pot or jack cracks its own joints over time and gives you exactly this on-and-off fault.
Fix 4: A volume or tone knob does nothing
- Volume does nothing. A lug on the volume pot is unsoldered or wired to the wrong terminal. Recheck the three pot lugs against your diagram: signal in, signal out, and ground to the back of the case.
- Tone does nothing. The tone control works through a small capacitor that bleeds high frequencies to ground. If the tone never changes, the capacitor or the pot is miswired, or the capacitor’s ground leg is not actually grounded. Recheck the pot and the cap against the diagram. The capacitor ties the pot to ground.
- Confirm the pot’s back is grounded to your one common ground point. A floating pot case can cause both noise and dead controls.
Many acoustic-electric and bass kits arrive pre-wired, so there is nothing to solder. If one of those is silent:
- Reseat every labeled plug and connector fully. A half-seated plug is the usual cause.
- On an active or piezo system, fit a fresh 9-volt battery. These circuits only wake up with a good battery.
- Plug a cable all the way into the jack. On a piezo and onboard preamp, the cable is what powers the circuit, so no cable means no sound.
Test before you close it up
If yours is a hollow-body or semi-hollow with the harness still out, prove the whole circuit works before you fish everything back inside. Once the harness is sealed in a hollow body you cannot reach a joint to fix it. Run the full tap test, every selector position, and both controls first, then close it up.
When to stop and ask
If you have worked the whole list and it is still silent, do not force anything.
If you have a Guitar Kit World kit and the issue is with the kit itself, such as a missing or damaged part, email our support team at [email protected]. Include the email address you used for your purchase, your order number, and a couple of photos, and the team will get you sorted out quickly.
For the full circuit, grounding, and soldering reference this guide draws on, see the Guitar Kit Wiring and Soldering Fundamentals module.
