HH Wiring Diagram — 2 Volume, 2 Tone, 3-Way Toggle Switch
HH (2 Humbuckers) — 2 Volume, 2 Tone, 3-Way Toggle Switch
HH (2 Humbuckers) wiring diagram
Download wiring diagram (PDF)
**Download Version 2 — updated layout (PDF)
Download Version 3 - updated layout (PDF)**
If your kit’s wiring doesn’t match the diagram above, try this version.
GKW kits that use this wiring
  • LP-style: LP-C-1, LP-RMBC-1, LP-RMBC-2, LP-RMRC-1, LP-RMRC-947, LP-RMFB-1, LPH-C-1, LPH30-C-1, LP7-C-1
  • G-style: SG-C-1, SG-RMRC-1, SG-RMEG-1, SG7-C-1
  • EXP-style: EXP-C-1, EXP-RMRC-1
  • V-shape: V57-C-1, V83-C-1, VR-RMRC-1
  • FB-style: FB-C-1, FB-RMRC-1
  • Semi-hollow: E335-C-1, E335-RMRC-1, E35-RMRC-1, E175-RMRC-1, E75-RMRC-1, E25-RMRC-1
  • PR-style: PR-C-1, PR-RMBC-1, PRH-C-1
  • Double-cut: DB-C-1, DB-RMRC-1
  • ICE-style: ICE-C-1, ICE7-C-1
  • Others: RD-C-1, RD2-C-1, SOB-C-1, NI-C-1, MOS-C-1, G1-RMRC-1, R25-RMRC-1, R330-RMRC-1, L3-RMRC-1, L5-RMRC-1, JG-C-1
Tips
  • This is the most common wiring for LP, SG, EXP-style, V-shape, ES-335, and similar dual-humbucker guitars with independent volume and tone per pickup. Each volume knob controls one pickup. If your wiring doesn’t match, try Version 2 below.
Building a Guitar Kit World kit with this wiring? Our HH Wiring Diagram page lists exactly which GKW kits use it, and if you own one of our kits and no diagram matches your electronics, we will draw you one.
